You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '?note=1 AND status = '1'' at line 2
KonstantinSpb писал(а):Пробую задать вопрос в форме для поддержки , а мне :You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '?note=1 AND status = '1'' at line 2
